| Field name |
Field type |
Description |
| id |
Int |
Unique identifier of the schematic dataset
Not null |
| major |
Int |
Release number of the dataset version; not used at this time
Not null |
| minor |
Int |
Minor release number of the dataset version; not used at this time
Not null |
| bugfix |
Int |
Patch or service pack number of the dataset version; not used at this time
Not null |
| dbname |
Varchar(32) |
Name of the database in which the schematic dataset is stored
| owner |
Varchar(32) |
The user who created the schematic dataset
| name |
Varchar(128) |
The name of the schematic dataset
Not null |
| extclsid |
Varchar(38) |
Not currently in use
| spatialref |
Varchar(1024) |
Default spatial reference used when creating new diagrams
| blobs |
Blob |
Stores the default parameters for the dataset, such as the default node symbol, text separator, and character
| Field name |
Field type |
Description |
| id |
Int |
Uniquely identifies a diagram type
Not null |
| objectclassid |
Int |
Foreign key to the id field in the sch_uniqueid table
Not null |
| creationname |
Varchar(255) |
Name of the diagram class when the table is created
Not null |
| name |
Varchar(255) |
Current name of the diagram class (if it was changed from the original name)
Not null |
| parentid |
Int |
Id of the parent diagram class entry
Not null |
| datasourceid |
Int |
Foreign key to the id field of sch<id>_datasrc |
| builderclsid |
Varchar(38) |
Class id for the schema builder (custom query, network dataset, or standard)
| linkerclsid |
Varchar(38) |
Component managing feature to element relationship method
| algorithmclsid |
Varchar(38) |
Class id of the algorithm that is automatically applied to diagrams of this type
| blobs |
Blob |
Stores all the attribute and symbology information
| Field name |
Field type |
Description |
| id |
Int |
Uniquely identifies an element type
Not null |
| objectclassid |
Int |
Foreign key to id in gdb_objectclasses table
Not null |
| creationname |
Varchar(255) |
Name of the element class when the table is created
Not null |
| name |
Varchar(255) |
Current name of the element class (if it changed)
Not null |
| parentid |
Int |
Id of the parent element class entry |
| elementtype |
Int |
Value specifying the type of element (node, link, etc.) |
| relationclsid |
Varchar(38) |
Relationship to a feature class
| associateddsid |
Int |
Data source id of related feature class
| associatedocid |
Int |
Id of the related feature classes from the gdb_objectclasses table
| datasourceid |
Int |
Foreign key to the ID field in the sch<id>_datasrc table
| blobs |
Blob |
Stores attribute and symbology
| Field name |
Field type |
Description |
| id |
Int |
Not null |
| name |
Varchar(255) |
Name of the diagram |
| folderid |
Int |
Foreign key to the sch<id>_folder table
Not null |
| diagramclassid |
Int |
Foreign key to sch<id>_diaclass table's objectclassid field
Not null |
| lastupdate |
Datetime |
Date and time of last user update
Not null |
| version |
Varchar(255) |
If generated from versioned data, lists which version
| creationdate |
Datetime |
Date and time diagram was created
| creator |
Varchar(100) |
Name of the user that created the diagram
| updatedby |
Varchar(100) |
Name of the user that last updated the diagram
| spatialref |
Char(1024) |
Spatial coordinates
| blobs |
Blob |
Stores the current positioning of all elements in the diagram
| Field name |
Field type |
Description |
| id |
Int |
Not null |
| diagramclassid |
Int |
Foregn key to the sch<id>_diaclass table's objectclass id field
Not null |
| diagramobjectid |
Int |
Foreign key to the sch<id>d_<diagram_type_name> table
Not null |
| schematicid |
Varchar(128) |
Uniquely identifies an element; consists of diagramobjectid, diagramclassid, datasourceid, ucid, uoid, and usid
Not null |
| isinitial |
Int |
Indicates whether this element was part of the initial creation list
Not null |
| isdisplayed |
Int |
Indicates whether this element is currently displayed
Not null |
| relationobjectid |
Int |
Object id of related feature in relationship
| relationclassid |
Int |
Class id of related feature in relationship
| datasourceid |
Int |
Foreign key to sch<id>_datasrc table
| ucid |
Int |
Class id of corresponding feature
| uoid |
Int |
Object id of corresponding feature
| usid |
Int |
Subtype id of corresponding feature
| ueid |
Int |
Enabled value of corresponding feature
| subtype |
Int |
Subtype of feature
| propertyset |
Blob |
Holds attribute information
| initialx |
Decimal(32,20) |
X positon of element when created
| initialy |
Decimal(32,20) |
Y position of element when created
