| <LEGEND | Attribute Description Table |
When parent element is IMAGE: file="string" type="gif | jpg | png | png8" url="string" When parent element is PROPERTIES and using ArcMap Server: autoextend="true | false" [false] backgroundcolor="0,0,0 - 255,255,255" display="true | false" [true] font="Any system font" [Arial] layerfontsize="1 - NNN" [10] swatchheight="integer" [14] swatchwidth="integer" [18] title="string" titlefontsize="1 - NNN" [12] valuefontsize="1 - NNN" [8] When parent element is PROPERTIES and using Image Server: antialiasing="true | false" [true] autoextend="true | false" [false] backgroundcolor="0,0,0 - 255,255,255" cansplit="true | false" [false] cellspacing="integer" [2] columns="integer" [1] display="true | false" [true] font="Any system font" [Arial] height="1 - NNN" [300] layerfontcolor="0,0,0 - 255,255,255" [0,0,0] layerfontsize="1 - NNN" [10] layerfontstyle="regular | bold | italic | underline | outline | bolditalic" [bold] reverseorder="true | false" [false] splittext="string" [(cont)] swatchheight="integer" [14] swatchwidth="integer" [18] title="string" titlefontcolor="0,0,0 - 255,255,255" [0,0,0] titlefontsize="1 - NNN" [12] titlefontstyle="regular | bold | italic | underline | outline | bolditalic" [bold] transcolor="0,0,0 - 255,255,255" valuefontcolor="0,0,0 - 255,255,255" [0,0,0] valuefontsize="1 - NNN" [8] valuefontstyle="regular | bold | italic | underline | outline | bolditalic" [bold] width="1 - NNN" [125] > When parent element is IMAGE: No Child Elements When parent element is PROPERTIES and using ArcMap Server: No Child Elements When parent element is PROPERTIES and using Image Server: (m)<LAYERS... /> </LEGEND > | |
| (m): Child element can be used multiple times. | |
| Attributes available when using an Image Service and no layers contain a value map. |
| Attributes available when using an Image Service and at least one layer contains a value map. |
| Attributes available when using an ArcMap Image Service and no layers contain a value map. |
| Attributes available when using an ArcMap Image Service and at least one layer contains a value map. |
| Attribute | Usage |
| file | Full pathname and filename for location of legend image generated by the ArcIMS Spatial Server. Image is written to the ArcIMS Spatial Server's output directory by default. UNC pathnames are valid (\\myComputer\arcims\output). |
| type | Returned when OUTPUT method="stream" in a map configuration file for Image Services. Valid only when the Java Connector, the Web ADF for the Microsoft .NET Framework, or the Web ADF for the Java Platform is used. |
| url | URL used by client to retrieve legend image. |
| Attribute | Usage |
| autoextend | Extends the legend to accommodate information for all layers. Should always be set to "true" with ArcMap Server. |
| backgroundcolor | Legend?s background color using RGB values. |
| display | Turns legend on or off. |
| font | Font for title. The name is case sensitive. If font name uses "&", use "&" instead. For example, ESRI Transportation & Civic should be written as ESRI Transportation & Civic. |
| layerfontsize | Font size for the layer labels. |
| swatchheight | Height of the symbol swatch in pixels. |
| swatchwidth | Width of the symbol swatch in pixels. |
| title | Title of legend. |
| titlefontsize | Font size for the legend title. |
| valuefontsize | Font size for the value map labels. |
| Attribute | Usage |
| antialiasing | Used to make edges of labels and symbols smoother. When set to "true", antialiasing is active. Note that the time to generate a map may significantly increase when antialiasing is turned on. |
| autoextend | If "true", automatically extends legend vertically past size specified in height, if needed. |
| cansplit | Allows splitting of valuemap layers between columns. |
| cellspacing | Defines number of pixels to pad between entries. |
| columns | Defines number of columns in legend. |
| font | Font for title. The name is case sensitive. If font name uses "&", use "&" instead. For example, ESRI Transportation & Civic should be written as ESRI Transportation & Civic. For Feature Services, the font must reside on the client machine or else the system default font is used. |
| height | Legend height in pixels. |
| layerfontcolor | Font color for the layer lables. |
| layerfontstyle | Font color for the layer labels. |
| reverseorder | Reverse order of layers. |
| splittext | Text that displays in bottom of a column if a valuemap is carried over into the next column. |
| titlefontcolor | Font color for the legend title. |
| titlefontstyle | Font color for the legend title. |
| transcolor | Transparency color using RGB values. White is 255,255,255. |
| valuefontcolor | Font color for the value map labels. |
| valuefontstyle | Font color for the value map labels. |
| width | Legend width in pixels. |
| <?xml version="1.0" encoding="UTF8"?> <ARCXML version="1.1"> <RESPONSE> <IMAGE> <LEGEND url="http://mymachine.domain.com/output/Iextensions_MYMACHINE4094163.jpg" /> </IMAGE> </RESPONSE> </ARCXML> |
| <?xml version="1.0" encoding="UTF8"?> <ARCXML version="1.1"> <RESPONSE> <IMAGE> <LEGEND file="D:\ArcIMS\output\Iextensions_MYMACHINE4094163.jpg" url="http://mymachine.domain.com/output/Iextensions_MYMACHINE4094163.jpg" /> </IMAGE> </RESPONSE> </ARCXML> |
| <?xml version="1.0" encoding="UTF-8"?> <ARCXML version="1.1"> <REQUEST> <GET_IMAGE> <PROPERTIES> <LEGEND title="Legend" font="Arial" autoextend="true" columns="1" width="170" height="300" backgroundcolor="255,255,0" > <LAYERS> <LAYER id="0"/> <LAYER id="1"/> </LAYERS> </LEGEND> <DRAW map="false"/> </PROPERTIES> </GET_IMAGE> </REQUEST> </ARCXML> |
| <?xml version="1.0" encoding="UTF-8"?> <ARCXML version="1.1"> <CONFIG> <ENVIRONMENT> <LOCALE country="US" language="en" variant="" /> <UIFONT color="0,0,0" name="Arial" size="12" style="regular" /> <SCREEN dpi="96" /> </ENVIRONMENT> <MAP dynamic="true" > <PROPERTIES> <ENVELOPE minx="-180.0" miny="-90.0" maxx="180.0" maxy="90.0" name="Initial_Extent" /> <MAPUNITS units="decimal_degrees" /> <FILTERCOORDSYS id="4326" /> <FEATURECOORDSYS id="4326"/> <LEGEND title="Legend" font="Arial" autoextend="true" columns="1" width="170" height="300" backgroundcolor="255,255,0" > <LAYERS> <LAYER id="0"/> <LAYER id="1"/> </LAYERS> </LEGEND> </PROPERTIES> <WORKSPACES> <SHAPEWORKSPACE name="shp_ws-0" directory="<path to WORLD ESRIDATA>" /> <SHAPEWORKSPACE name="shp_ws-2" directory="<path to USA ESRIDATA>" /> <SHAPEWORKSPACE name="shp_ws-3" directory="<path to CANADA ESRIDATA>" /> </WORKSPACES> <LAYER type="featureclass" name="WORLD30" visible="true" id="0"> <DATASET name="WORLD30" type="polygon" workspace="shp_ws-0" /> <SIMPLERENDERER> <SIMPLEPOLYGONSYMBOL filltype="solid" fillcolor="0,153,255" /> </SIMPLERENDERER> </LAYER> <LAYER type="featureclass" name="CNTRY94" visible="true" id="1"> <DATASET name="CNTRY94" type="polygon" workspace="shp_ws-0" /> <SIMPLERENDERER> <SIMPLEPOLYGONSYMBOL filltype="solid" fillcolor="255,255,153" /> </SIMPLERENDERER> </LAYER> <LAYER type="featureclass" name="United States" visible="true" id="2"> <DATASET name="STATES" type="polygon" workspace="shp_ws-2" /> <SIMPLERENDERER> <SIMPLEPOLYGONSYMBOL filltype="solid" fillcolor="255,0,0" /> </SIMPLERENDERER> </LAYER> <LAYER type="featureclass" name="Canada" visible="true" id="3"> <DATASET name="province" type="polygon" workspace="shp_ws-3" /> <SIMPLERENDERER> <SIMPLEPOLYGONSYMBOL filltype="solid" fillcolor="0,153,0" /> </SIMPLERENDERER> </LAYER> <LAYER type="featureclass" name="World Cities" visible="true" id="4"> <DATASET name="CITIES" type="point" workspace="shp_ws-0" /> <SIMPLERENDERER> <SIMPLEMARKERSYMBOL color="102,0,102" width="8.0" /> </SIMPLERENDERER> </LAYER> </MAP> </CONFIG> </ARCXML> |
| <?xml version="1.0" encoding="UTF-8"?> <ARCXML version="1.1"> <RESPONSE> <IMAGE> <ENVELOPE minx="-180" miny="-135" maxx="180" maxy="135" /> <OUTPUT type="jpg">/9j/4AAQSk ... ZJRgABZ</OUTPUT> <LEGEND type="jpg" >/9j/4AAQSkZJRgABAQA ... UDBAQEAZ</LEGEND> </IMAGE> </RESPONSE> </ARCXML> |
