Administering a database server
Release 9.3
This topic was updated for 9.3.1.
This topic contains links to administration concepts and instructions that apply to ArcSDE database servers.
ArcSDE database servers are instances of Microsoft SQL Server Express that have been enabled to store geodatabases. An installation file for SQL Server Express is included with ArcGIS ArcEditor and ArcInfo, ArcGIS Engine, and ArcGIS Server Workgroup. Also included is a postinstallation setup wizard that enables the SQL Server Express instance to store geodatabases, adds an administrative user to the database server, and—for ArcGIS Server Workgroup—authorizes the software. Be sure to read the
installation guide
that comes with ArcGIS Desktop, ArcGIS Engine, or ArcGIS Server Workgroup to install SQL Server Express and run the postinstallation setup, because the guide contains step-by-step instructions. A summary of this can be found in the following topic:
Installing SQL Server Express and enabling it to store ArcSDE geodatabases
Once the database server exists, you use ArcCatalog to connect to it.
An overview of database server connections
Adding an ArcSDE database server
Saving a geodatabase connection
Troubleshooting connections to the database server
Next, create a geodatabase.
Creating a new geodatabase
If you have an existing geodatabase from another database server user, you can attach the geodatabase to the database server.
Detaching and attaching a geodatabase on a database server
Add users to the database server and grant them permissions.
Adding and removing users or groups for ArcSDE database servers
User permissions for geodatabases on ArcSDE database servers
Administering user permissions for ArcSDE database servers
Add data to the geodatabase. This is done the same way you would add data to a personal or file geodatabase. The only difference is you must be logged in to the client computer with a login that has sufficient privileges to create data in a geodatabase.
Some ways to add data are explained in the following links:
Creating new datasets using ArcCatalog
Copying feature datasets, classes, and tables to another geodatabase
An overview of importing datasets
Loading data in ArcCatalog
Loading data in ArcMap
Loading features or records from an export file
Once data has been added to or created in the geodatabase, you need to grant users permission to the data and maintain the geodatabase.
Granting and revoking privileges on datasets
Back up and restore geodatabases on an ArcSDE database server
Compressing a geodatabase on an ArcSDE database server
Updating statistics on geodatabases on ArcSDE database servers
Rebuilding indexes on a geodatabase on an ArcSDE database server
Shrinking geodatabases
Upgrading geodatabases on ArcSDE database servers
When administering a database server, you may need to disconnect from or delete it from the Catalog tree. You might also need to stop or suspend the database server so users cannot connect to it.
Disconnecting from an ArcSDE database server
Deleting an ArcSDE database server
See Also
An overview of ArcSDE geodatabase administration
