Beginning with Oracle 11
g, LONG RAW data types are no longer supported. It is possible your current ArcSDE geodatabase in Oracle contains LONG RAW fields. You might have attribute columns, geometry columns, or columns in the raster side tables that use LONG RAW storage. The storage for these columns is controlled by the DBTUNE parameters ATTRIBUTE_BINARY, GEOMETRY_STORAGE, and RASTER_STORAGE respectively.
The defaults for these parameters under the DBTUNE DEFAULTS configuration keyword have changed. The following table shows the default setting under the DEFAULTS keyword in the DBTUNE table in ArcSDE 9.3, 9.2, and prior geodatabases.
| Parameter |
Default at ArcGIS 9.3 |
Default at ArcGIS 9.2 |
Default prior to ArcGIS 9.2 |
| ATTRIBUTE_BINARY |
BLOB |
BLOB |
LONG RAW |
| GEOMETRY_STORAGE |
ST_GEOMETRY |
LONG RAW (SDEBINARY) |
| RASTER_STORAGE |
BLOB |
LONG RAW |
LONG RAW |
Data created in new 9.3 geodatabases using the default parameter settings for ArcGIS 9.3 do not use the LONG RAW storage type. However, any existing data created with any or all of these parameters set to LONG RAW or any new data in upgraded geodatabases that have these parameters set to LONG RAW will still contain LONG RAW columns. To change the data types for these columns, you must alter your DBTUNE settings and migrate the data.
Beginning with ArcGIS 9.3, you can use the Migrate Storage geoprocessing tool, ArcSDE administration commands, ArcObjects, or the ArcSDE API to migrate existing LONG RAW columns to another data type. Additionally, you can migrate other geometry storage data types to ST_GEOMETRY storage. Possible migration paths include the following:
| Parameter |
Migrate from/to |
| ATTRIBUTE_BINARY |
LONG RAW to BLOB |
| GEOMETRY_STORAGE |
LONG RAW (SDEBINARY) to BLOB (SDELOB) |
LONG RAW to ST_GEOMETRY |
BLOB to ST_GEOMETRY |
SDO_GEOMETRY to ST_GEOMETRY |
| RASTER_STORAGE |
LONG RAW to BLOB |
If the table was registered as versioned, migrating it to a different geometry storage type also updates the shape column in the Adds table. If the feature class has archiving enabled, the archive table's shape column is also updated.
The following conditions must be met before you convert your data:
- You must make a backup of the data before you migrate it.
- If you are converting the spatial column type, the data must be stored in high precision. If your data is currently stored with low (basic) precision, you must first migrate it to high precision before you migrate the storage type. This can be done with either the Upgrade Spatial Reference geoprocessing tool or the sdelayer command with the alter operation. See Migrating to high precision for information on migrating a dataset's precision.
- If you are converting the spatial column, the table must contain an object ID column. Registering the table with the geodatabase will automatically add this column, or you can use the sdetable command with the alter_reg operation to add it.
- You must be the owner of the table that contains the column being migrated.
- The configuration keyword you specify when migrating the data type has to contain the correct value for the GEOMETRY_STORAGE, ATTRIBUTE_BINARY, or RASTER_STORAGE parameter. For example, if you want to migrate a LONG RAW geometry column to ST_GEOMETRY, but you specify a keyword that has the GEOMETRY_STORAGE parameter set to SDO_GEOMETRY, the migration will fail.
- When data is migrated from one data type to another, a new segment is created in the database to which the data is copied. Once the migration is complete, the metadata gets repointed to the new segment and the old one is deleted. That means during the migration, there are two copies of the data; therefore, make sure you have enough room in the database for two copies of the data. This is mostly an issue when migrating raster data from LONG RAW to BLOB.
Since both attribute and raster storage will be migrated to a BLOB data type and BLOB is an option for the conversion of geometries, it is recommended that you read the topic
BLOB data storage in Oracle geodatabases before proceeding with the migration instructions.
The following sections describe how to migrate the attribute, geometry, or raster storage of a table in an ArcSDE geodatabase in Oracle.
Migrating geometry columnsYou can change the geometry storage used in a feature class in a geodatabase in Oracle by using the migrate operation with the sdelayer command. The migrate operation changes the geometry storage of the feature class to the geometry storage type in the DBTUNE configuration keyword you specify with the –k option.
The syntax for the sdelayer command with the migrate operation is as follows:
sdelayer –o migrate –l <table,column> –k <config_keyword> [–i <service>]
[–s <server_name>] –u <DB_user_name> [–p <DB_user_password>] [–N]
Where
–l specifies the name of the business table of the feature class and the shape column.
–k designates the DBTUNE configuration keyword for the geometry storage type to which you are migrating the feature class. The keyword must contain a GEOMETRY_STORAGE parameter set to either SDELOB or ST_GEOMETRY.
–i indicates the ArcSDE service or direct connection information.
–s defines the name of the server on which the database resides.
–u specifies the database user name of the feature class owner.
–p specifies the password of the user.
–N suppresses the prompt to confirm the operation.
You will receive an error message when you execute this command if any of the following is true:
- The user specified with –u is not the feature class owner.
- The existing storage type of the feature class and the specified DBTUNE keyword are identical. (In other words, the feature class is already using the geometry storage type you specified with the keyword.)
- You try to use the migrate operation in an ArcSDE 9.2 or earlier geodatabase.
Migrating attribute and other LONG RAW columnsYou can migrate LONG RAW attribute columns to BLOB using the sdetable command with the migrate operation. This operation changes the storage of the attribute column from LONG RAW to BLOB by specifying a DBTUNE configuration keyword that has the ATTRIBUTE_BINARY parameter set to BLOB.
You can also use sdetable to migrate all the LONG RAW columns in a table at once. For example, if you have a feature class that is using LONG RAW raster storage and contains a binary attribute column of LONG RAW, when you use sdetable, both columns are converted based on the parameters set in the configuration keyword you specify with the –k option. As long as the specified configuration keyword contains both an ATTRIBUTE_BINARY parameter set to BLOB and a RASTER_STORAGE parameter set to BLOB, both column data types will be converted.
The syntax for sdetable –o migrate is as follows:
sdetable –o migrate –t <table> –k <config_keyword> [–i <service>]
[–s <server_name>] –u <user_name> [–p <user_password>] [–N] [–q]
Where
–t specifies the name of the table containing the column (or columns) to be migrated.
–k designates the DBTUNE configuration keyword for the storage type to which you are migrating.
–u specifies the database user name of the table owner.
As with the other commands, the migration will fail if you are not the owner of the table, you try to migrate a table in a pre-9.3 geodatabase, or there are no valid parameters included with the specified configuration keyword.
Tip
- Be sure you have a backup of copy of any data you intend to migrate. That way, if migration fails for any reason, you still have your original data.
