aimses.cfg reference for Extract Server expand/collapse all
Related Topics
Changing the maximum output file size for data extraction
Setting connection parameters for ArcSDE
Adding an extract extension
expand/collapse item About aimses.cfg
Aimses.cfg specifies default Spatial Server settings for Extract Server and is located at:
Windows: <ArcGIS Installation Directory>\ArcIMS\Server\etc
UNIX and Linux: $AIMSHOME/etc
The following settings can be changed:
After making any changes to this file, you must restart ArcIMS Monitor and ArcIMS Application Server.
Search code: @ref_aimses
