When using ArcSDE, you can set whether or not to preload all data in a raster catalog, set the method for counting features, pool Spatial Server instances connected to ArcSDE, and set a connection check interval.
Two modes are available when counting ArcSDE features. When client mode is used, all features are counted by the ArcIMS Spatial Server, which in this case is a client to ArcSDE. When server mode is used, all features are counted using a log file in ArcSDE. The default is client mode and is the recommended configuration. In some cases, when very large datasets are in use, server mode counting may be faster. You must use this mode with caution. When server counting is used, the feature limits you set in your map configuration file or in Spatial Server configuration files are ignored and no limit can be placed on the number of features a user can request. When using shapefiles, counting is always client mode.
You can pool Spatial Server instances connected to ArcSDE. This feature was added originally when licensing of ArcSDE limited the number of connections available for ArcIMS. Since there is no longer a limit on ArcSDE connections available to ArcIMS, it is recommended not to change the defaults.
When you start an ArcIMS Service accessing data in ArcSDE, one or more connections per Spatial Server instance is made to ArcSDE. By default, all server functions, such as Image Server or Query Server, have one connection to ArcSDE per Spatial Server instance. The exception is Geocode Server, which has three connections. These connections are persistent and remain whether ArcIMS services are stopped or running. Exercise caution when using connection sharing since changing the defaults may adversely affect performance.
The connectioncheckinterval defines the time interval between attempts to reconnect to ArcSDE when an ArcSDE server is unavailable. For more information, see Setting timeouts.
Windows: <ArcGIS Installation Directory>\ArcIMS\Server\etc
UNIX and Linux: $AIMSHOME/etc
| ArcMap Image | aimsamsrv.cfg |
| Feature | aimsfs.cfg |
| Extract | aimses.cfg |
| Geocode | aimgc.cfg |
| Image | aimsms.cfg |
| Metadata | aimsmd.cfg |
| Query | aimsqs.cfg |
