Using ArcIMS 9.2
Locating and pointing to font directories expand/collapse all
Related Topics
aimsms.cfg reference for Image Server
expand/collapse item About font locations
The Spatial Server needs to know the location of fonts on the machine in order to render maps correctly.
On UNIX and Linux machines, the Spatial Server looks for fonts in the following locations:
On Windows, the Spatial Server looks for fonts in the following locations:
expand/collapse item How to point to font directories
expand/collapse item Referencing font directories in aimsms.cfg
  1. In a text editing application, open aimsms.cfg.
    Windows: <ArcGIS Installation Directory>\ArcIMS\Server\etc
    UNIX and Linux: $AIMSHOME/etc
  2. Add a directory for the fontdirectory value. Multiple directories can be listed. On Windows, separate the directories with a semicolon. On UNIX and Linux, use a colon.
  3. Repeat the above steps as needed to make the same changes on each machine in your site configuration with a Spatial Server.
  4. Restart ArcIMS Monitor and ArcIMS Application Server.
Search code: @stability_fonts
