Custom Metadata Profiles Overview |
| Release 9.3.1 |
The Geoportal extension provides metadata publishers with the ability to create metadata that conforms to any standard using an online Metadata Editor. To access the Metadata Editor, a user with publisher permissions logs in, selects the Administration tab, and then selects "Create" from Metadata menu options. The resulting Metadata Editor supports several popular metadata standards out-of-the-box. When these standards do not suit your organization's needs, the Geoportal extension can be customized to support other metadata standards or create your own standard for use within your organization.
An understanding for how the Geoportal extension uses Search syntax will be useful as you read this section. The Using Search topic explains how the search page can be customized to search different fields in a metadata document, how more terms can be indexed for searching, how to use search syntax, and more.
Sections:
