Setting the scale dependency of labels expand/collapse all
Related Topics
Setting the scale dependency of symbols and renderers
Labeling layers
Setting a layer's scale dependency
Using shields with line layers
expand/collapse item About label scale dependency
Setting scale dependency involves establishing maximum and minimum display scales for labels. If you set the scale dependency of a layer's labels, the labels will not appear when zoomed in or out beyond the maximum and minimum scales.
The scale dependency of labels is set on the Labels tab of the Layer Properties dialog box. Scale dependency of symbols must be set separately and does not affect the scale dependency of labels.
expand/collapse item How to set scale dependencies for labels
expand/collapse item Setting and removing the scale dependency of labels
  1. Click a layer in the legend to make it active.
  2. Click the Layer Properties button Add Layers button on the Author toolbar to open the Layer Properties dialog box.
  3. Click the Labels tab.
  4. Click the Set scale dependent renderer button.
    The Scale Dependent Renderer dialog box appears.
  5. To add scale factors, type a minimum and/or maximum scale factor.
  6. Click the Zoom to scale button next to the Minimum or Maximum text box to Zoom to the specified scale.
    If you are unhappy with the scale range, repeat the previous two steps until you arrive at acceptable maximum and minimum scale factors.
  7. To remove scale factores, remove any values from the scale factor boxes.
  8. Click OK on the Scale Dependent Renderer dialog box to apply your changes.
  9. Click OK to close the Layer Properties dialog box.
Search code: @author_labels_scaledep
