You can set options that apply to the application and are retained from session to session.
To display the ArcGIS Explorer Options dialog, click the ArcGIS Explorer Button
, then click the ArcGIS Explorer Options button:
Set these options
Common
The Common options represent the set of options that are common user preferences. These are not necessarily the most important options for ArcGIS Explorer, but they do represent those options for which each individual tends to have their own favorite.
Learn more about the Common options
Top of Page
Map Window
The Map Window options define the behavior of the orientation indicator, the Navigator, and whether to show position information and whether to display an indicator that shows the target position.
Learn more about the Map Window options
Top of Page
3D Display Effects
The 3D Display Effects options provide a means to control sun lighting and fog effects.
Learn more about the 3D Display Effects options
Top of Page
Layers
The Layers options control whether the Swipe and Transparency controls work on the selected layer or on the selected layer and all layers above it.
Learn more about the Layers options
Top of Page
Flight Characteristics
The Flight Characteristicsoptions represent the set of options that you can use to control the flight behavior of the application when flying point-to-point or following a route. In addition, you can control whether to avoid the terrain when panning and flying.
Learn more about the Flight Characteristics options
Top of Page
Navigation
The Navigation options allow you to control the speed with which you navigate over the map using the mouse, the keyboard, or the Navigator control. In addition, these options set the behavior of the mouse in the application.
Learn more about the Navigation options
Top of Page
Advanced
The Advanced options represent the set of options that are less frequently or rarely used options that you can set to manage proxy server authentication, cache management, and symbols.
Learn more about the Advanced options
Top of Page
Resources
The Resources panel provides a way of finding online resources, incorporating add-ins, determining version information about the application, and checking for updates.
Learn more about the Resources options
Top of Page
